Backtire Wobble From Wheel Hubs
2001 raptor
Lonestar axcaliber axle
I have two sets of rear tires/wheels, and they both wobble mucho bad. I have the stock wheel hubs and they have excessive play on the axle when the nuts are loose or off. When i tighten them up the nuts kinda kick them sideways, which is where my wobble is comeing from. I was curious if anyone else has had this problem ? Also the nuts keep comeing loose as well, I assume from wear...
Sounds like they might have wore when it was ridden with them loose, I have a lonestar and my stock hubs usually try and work loose also to the point of actually cutting the cotter pins. I used some red loctite and it seems to be holding but your situation seems a little more severe and may need replacement hubs.
badgerboy1
09-26-2017 06:11 PM
10-10-2015 10:20 AM
