What Piston to run after HOTCAM Put in!!!!!!
The more compression the less reliable you will be. There isn't really a problem until you get like 12.5/1 then the head gasket becomes an issue, or has for some people. The more compression the more power. The more compression you have the hogher octane gas you need to run.
is that all i would need with the hotcam ,springs and what else
Barlett's right about the rod![img]i/expressions/face-icon-small-disgusted.gif[/img]
