timing chain stretch?????/
Old Dec 22, 2002 | 08:21 PM
risner151's Avatar
Default timing chain stretch?????/
i revved my raptor blipping the throttle and it said gllethhglethth died....i thought the timing chain broke...took the valve cover off the chain was loose on the cam sprocket.i took the chain tensoiner out....
before when putt ing the raptor in time i dont think the chain was long enough to slip on the bottom gear.. now it does...im pretty sure the gear on the crank isnt stripped but havent checked yet. when you broke into your motor did the chain slip on the bottom gear when turning the cam w/ no tensioner in?
_________________
Old Dec 22, 2002 | 08:43 PM
risner151's Avatar
id say it is definatly stretched ... it is a 686 w/ 696/697 web cam and dual rate wibblewhite springs... is there a heavy duty chain?
Old Dec 22, 2002 | 10:29 PM
risner151's Avatar
well here is another case!!!! i did have a low oil level...before i built this motor i had a 11:1 motor and while riding my clutch side cover started leaking reallly really badd...for no reason... i rode back to camp.. i took the cover off resiliconed it and it s fine...so youre probably correct w/o sufficient topend iol theres more friction esspecially w/ the tougher valve springs so the chain stretches..
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
