Dynojet Springs vs Stock Springs
Old Dec 30, 2002 | 06:10 PM
ba01raptoraz's Avatar
Default Dynojet Springs vs Stock Springs
I read a long thread about cutting the springs and am still confused. In the Dynojet installation guide, they state that the supplied springs do not have to be used. They are supplied if the stock springs are misplaced.
Should I replace the stock springs? What enhancements are gained by simply swapping them out?
Old Dec 30, 2002 | 06:44 PM
THEMOOSE's Avatar
You need to re read your instructions!!
It says to install the Dynojet slide springs DSP206 (they are a diffrent tension & should be used)
The DSP77 springs are needle springs & are the same as stock & can be used as spares!
Old Dec 30, 2002 | 08:00 PM
Moose,
I reread the instructions, I got confused on the 77 springs in the note.
So once again, what is the advantage of the different tension?
Thanks for the reply.
Old Dec 31, 2002 | 01:35 AM
Chimmer's Avatar
The Dynojet springs are thinner to allow quicker throttle response. I think most people would agree not to use them since they are more prone to bounce & cause jetting difficulties. JMO!
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
shimanok2
Jan 29, 2016 07:37 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
CosmoM
Sep 21, 2015 04:57 PM
