RM blaster
Old Dec 31, 2002 | 11:27 AM
osrider's Avatar
Default RM blaster
My cousin has a 1983 RM 250. It runs like a top and we're putting a wiseco piston, and boyseen racing reeds in it and we're gonna get a slight bore. His frame on the other hand is in need of a little help. He needs a front right shock, rear monoshock,rear sprocket, and other things. We got the idea to put that motor into a quad. The a salvage cycle place with tons of frames and everything of bikes and quad that need motors. We want to put the engine into a quad frame. Theres alot of blasters up there and one or two lt 250r's. Would the Lt be a better choice? would it bold right up? We heard the engine is basically the same
Old Jan 1, 2003 | 05:00 AM
YFZRacer's Avatar
Default RM blaster
osider pm blaster2fast he was looking at building a yz250 blaster he might be able to tell you something
Old Jan 1, 2003 | 02:11 PM
osrider's Avatar
Default RM blaster
alright
Old Jan 1, 2003 | 03:25 PM
DutchBlaster's Avatar
Default RM blaster
I think the LT frame would be the best choice, because it was designed to handle more power than the Blaster frame.
You could probably mount the engine in the LT frame with less modifications. Just my $0.02.
Old Jan 1, 2003 | 06:20 PM
tom18801's Avatar
Default RM blaster
well if you go looking for a lt250 frame in a salvage yard it will probaly have a crackin the swingarm near the bearing carrier a cracked or bent frame and every bushing and bearing will be worn out
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
