TORS
Old Jan 7, 2003 | 07:29 PM
LOWBOWTIE's Avatar
Default TORS
I hear us shee owners need to know what this is. Well I don't!!!! Please let me know if I want to unhook it?[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 8, 2003 | 11:46 AM
AlkyBurninX's Avatar
Default TORS
Under the gas tank, above engine, left side of the bike on the tube that the coil is mounted on, there is a 1.25"X1.25" silver box with a wire set coming out of it. The wire is about 5" long and goes to a triangular plug with 3 pins. Unplug this and you are done. The TORS keeps the engine from reving if the throttle hangs. Unplugging this will do away with the limiter. Only unplug it if you feel safe not having the limiter.
Old Jan 8, 2003 | 01:09 PM
garyc660R's Avatar
Default TORS
If you are not having any troubles....leave the TORS junk on. TORS does'nt limit rpms...it's just a system that monitors throttle opening at the bars and compares that too how much throttle is applied at the carbs. If they are in sync...you ride...if they are not, the engine spits and sputters.
With the TORS removed and one / both carbs hang open (wide open usually) hope you have your spurs bolted on your boots...IT'S RODEO TIME. Your shee will run until it blows or something stops it.
Old Jan 8, 2003 | 05:14 PM
LOWBOWTIE's Avatar
Default TORS
Thanks guys, but if it was un hooked and took off (wide open) Couldn't you hit the kill switch? Would this turn it off? It's a new ride and every thing works fine ,so I'll leave it alone!
Old Jan 8, 2003 | 05:31 PM
MichaelAZ's Avatar
Default TORS
I have had it happen to me, i disabled the TORS and dont have any problems other than pull in the clutch pull the brakes and kill er, it only sticks when sand gets in the cable.sand gets in places you would never think of.
Old Jan 8, 2003 | 07:40 PM
albaBANSHE's Avatar
Default TORS
I think I found mine! but ill leave it alone!
Old Jan 8, 2003 | 10:27 PM
Default TORS
I didn't mean the TORS is a "rev limiter". Thank you Gary for clarifying my wording.
Old Jan 8, 2003 | 11:02 PM
xbox74's Avatar
Default TORS
take them off and put them on ebay for the $5.00 you will get for them!!!!! The more crap like that on a machine the more problems!! motion pro sells a kit that eliminates them for around $40.00 easy to install too!!! p.s. this kit makes it easier to remove the carbs for jetting
Old Jan 8, 2003 | 11:13 PM
Batoutahell's Avatar
Default TORS
They are fine, until they screw up. I had a trip planned for labor day weekend to go to st. anthony dunes, when loading up the night before I was tuning up the banshee and setting the idle speed and something happened to the boxes and now the idle would not come down. As soon as I started the quad, it would start to rev to the moon until I hit the kill switch.
I got up the next morning and called every place I could find between here and st. anthony looking for the tors removal kit. I could not find it. I found one at rocky mountain atv, which is on the way to little sahara utah, so I changed plans, and went there. Picked up the kit on the way. Installed it at the dunes, except for the idle screws and rode for the whole weekend.
My suggestion is get the kit, because when it stops working it might not be the best time for you. And I second the opinion that it makes it much easier to get at the carbs for jetting and whatnot.
Later
bat
Old Jan 9, 2003 | 10:36 AM
WyoDuner's Avatar
Default TORS
I agree, get rid of them. Mine started giving me trouble by cutting out when i hit the throttle then would kick in a second later. I can't tell you how NOT fun that was. Plus, it cleans up the whole area and makes getting to the carbs and jetting a lot easier.
315blaster
Aug 8, 2015 08:13 PM
selector
Sep 26, 2003 06:44 PM
raptorron
Aug 26, 2003 10:45 PM
Spoony
Aug 21, 2003 04:21 PM
hak231
Feb 18, 2003 05:01 PM
