tire changing
Old Jan 9, 2003 | 01:35 PM
eric32's Avatar
Default tire changing
what is the easiest way to get a tire of a rim ????? any ideas??i would apreache it
Old Jan 9, 2003 | 02:13 PM
XtremeRaptor's Avatar
If you're having alot of trouble getting the tire off, take it to your local tire shop and have them take it off for you!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 9, 2003 | 08:45 PM
Psycho's Avatar
Beads are a beotch to break. Unless you like pain and bleeding knuckles, then I agree with Xtreme...take 'em to a tire shop...Good Luck!!! [img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 9, 2003 | 08:56 PM
NotuRaptor2's Avatar
Buy a bead breaker from one of the magazine ads. Stock tires are the hardest to break.
The trick is to work your way around the rim slowly. You will not break the bead on the first try. Basically, you need to loosen the bead most of the way around before you finally get it stretched over the groove in the rim. If you weigh under about 180 lbs, you will most likely need help with someone standing on the rim.
Soap and water help too.
You need a good set of tire irons too for getting the tire off the rim. Buy at least one that is about 17" long or so. The stubby ones are okay as helpers but you really need one long one for leverage.
/Jon
Bratman2
Aug 6, 2022 01:42 AM
Ean
Aug 28, 2015 09:39 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
