raptor choke.
Old Jan 11, 2003 | 03:28 PM
raptor8's Avatar
Default raptor choke.
yup. mine sticks.
can i sneak in there and pull it out without gutting the quad? i'd rather not if possible... the service manual is no help.
thot somebody would have learned a trick to it. would appreciate any help. thanx a lot! [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 11, 2003 | 03:32 PM
ClutchOlds's Avatar
It could be the spring, undo the 12mm nut that holds it into the motor and pull it out. Inspect and Lube if ok, reinstall.
Old Jan 11, 2003 | 04:58 PM
RacinJason's Avatar
The choke cable allows water to travel down the sheathing and into your carb, pull the choke out(in bike)an replace it with some lube to help it move better, mine had corrosion and rust
BRAAAAP
Old Jan 11, 2003 | 05:08 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Without going outside to look at this, could you after you get it lubed up put some electrical tape or apply a small bead of silicone to prevent water from entering again.
Chet
Old Jan 11, 2003 | 06:25 PM
raptor8's Avatar
ok thanks guys!!
i was hoping i wouldnt have to strip the quad to get at it. sounds like i can sneak a wrench in there then...
thanx much! see yas [img]i/expressions/face-icon-small-happy.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
