slip on airfilters
Old Jan 15, 2003 | 07:04 PM
whitebread's Avatar
Default slip on airfilters
just ordered my slip on airfilters from uni airfilter to eliminate my entire airbox.what do i do with all those extra vacuum lines, especiallt the two big ones coming out of the carbs.do i just block them off or put a little airfilter in them and hook them to the frame?[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 17, 2003 | 07:57 PM
JustDragItBitch's Avatar
you can get some little filters that look like k&n's. just put 'em on and stick them where you like them best.you can get these at napa, o'reillys, etc. hope i helped you.
Old Jan 17, 2003 | 08:15 PM
RaptorRcR's Avatar
As I said on BT..you will more than likely lose hp by bolting them directly to the carbs..you definitely wont gain as much as if you did it the correct way...but do as you please. There are a few guys on here with dyno runs to back this up. The stock carbs NEED the velocity tubes as well as the vacuum lines to be hooked up.
Old Jan 17, 2003 | 08:26 PM
raptor03's Avatar
GOOD POINT!!!
Old Jan 17, 2003 | 08:28 PM
whitebread's Avatar
thanks rcr,i guess i will leave the velocity tubes on and hook the twin airfilters up to them
Old Jan 17, 2003 | 08:35 PM
RaptorRcR's Avatar
No problem...1 or 2 hp makes a huge difference[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 17, 2003 | 08:37 PM
whitebread's Avatar
no doubt about that.[img]i/expressions/face-icon-small-happy.gif[/img]
Jeff Roper
Feb 1, 2022 11:48 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
