T-Rex Banshee Powervalve Cylinder Kit?
Is this kit putting out the advertised 140 horsepower? If not does anyone know what it is churning? And does it run like 2000 dollars should?Is there a better bolt-on kit for this price that is better?I figure it's churning at least 100RWHP. am i right?
You didnt specify the stroke/bore specs of the motor. If you are running the big 10mil stroker version you can get anywhere from 125 horses to a *claimed* 140 horses. I seriously doubt these guys are getting what they say they are getting. Its easy to get high dyno numbers though by just running the engine lean on the dyno. The t-rexs do run hard. They are more work to port out of the box then some of the other cylinders out there, but they can be made to run extremely hard. Right now the t-rex's and the cheetahs are the cylinders to beat on the sand.
