compression tester....
Old Feb 11, 2003 | 05:21 PM
2fun's Avatar
Default compression tester....
Originally posted by: DAMAGEINC
go buy a cheap one at least you 'll have an idea plus it will tell you what you really want to know test it at wide open throttle, after it's warmed up, see what comes up if it's low do a second test with a table spoon full of oil down the plug hole if it goes up you know that yours rings are bad if not and it was low you need to check your valves
good luck
DAMAGE
I still say stay AWAY from a cheap one if you want to know the TRUE compression reading.
You have no idea what the TRUE compression is if you get a cheap one.
A cheap one should only be used for comparing the compression on YOUR motor when fresh and on YOUR motor after you have ring wear.
I suppose you could check a friends compression and then check yours with the same gauge, but if he doesn't have the exact same compression/compression ratio as you do, you are just pi$$ing in the wind!
Old Feb 11, 2003 | 06:00 PM
FISHER1648's Avatar
When ya check the compression and turn the motor over with the starter make sure you attach a battery charger to the battery so the starter works well enogh to generate enough RPMs to get past the compression release.
Old Feb 11, 2003 | 06:47 PM
BlueLeader's Avatar
thanks for the input guys. I have done compression tests and leakdowns before. I am going to get a good Snap-On guage and coast down my steet to see what the compression is. Just have to remember to put a plug in my pocket so I can ride back up the hill. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 11, 2003 | 08:58 PM
UBETRUN's Avatar
Note to self - Dumbass!
Sorry Damageinc.
Old Feb 12, 2003 | 09:48 PM
  #15
2fun's Avatar
Sorry Damageinc.
LOL!! Funny![img]i/expressions/face-icon-small-happy.gif[/img]
At least you were man enough to apologize.[img]i/expressions/face-icon-small-wink.gif[/img]
Thats something you don't see around here too often.[img]i/expressions/face-icon-small-sad.gif[/img]
Congrats on stepping up to the plate.[img]i/expressions/face-icon-small-smile.gif[/img]
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
