sorry guys,another jet question??
about what would be the proper jetting with the following?fmf exhaust system,pro flo air filter with no lid(had to get away from the slip ons,too many cons and not enough pros)11:1 piston,stage 1 hotcam?
big enough you could flow a friggin river through it !! the more fuel the better but you have to be able to get enough air to for the right mixture. but like i said the more the better
wshrdskin has the same set up you do except the pipe and I think he's using 150/155 DJs.
Here's his set up from another post
I have an 01 Raptor with 02 gears.
Sprockets 12/41 for the dyno run. 12/42 now cause I like it better with 22" Haulers.
Dyno jet kit running 150/155 mains, needle clips 4th from top, fuel air screws 3 turns out left 3 1/4 turns out right.
Port matched intake boots.
No lid on the airbox. K&N pro design filter and flange. With outerwear.
Complete Alba pipe with 18 disks. Not the 12 that came with it.
11:1 JE piston.
Hotcam stage 1 cam.
11:1 JE piston.
Hotcam stage 1 cam.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
