found my problem(timing chain broke)
Old Feb 20, 2003 | 08:59 PM
whitebread's Avatar
Default found my problem(timing chain broke)
evidently i didn't tighten one of the bolts on the cam sprocket.the bolt and the plate came off and got wedget between the timing cavity and the chain.they all done the bump and grind a little bit and got metal shavings all in the chain cavity.after further inspection i didn't see any shavings at the bottom of the crank case,thank god.do i need to take the oil pump off and inspect it?i couldn't find any other shavings anywhere besides the cavity.
got it tore all the way down to where i need a pulley puller and out of the frame in about an hour and a half,i knew i would be getting good at this.
Old Feb 20, 2003 | 09:08 PM
wshrdskin's Avatar
Hows the cam sprocket look? So you need a chain, possible cam sprocket and new weight assembly? Did you neglect to put blue loctite on the cam sprocket nuts? At least you know whats up and can get it fixed and back to riding. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 20, 2003 | 10:15 PM
whitebread's Avatar
im going to get the whole sprocket assembly just to be safe,and yes i did neglect to use loctite.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 20, 2003 | 10:33 PM
XtremeRaptor's Avatar
Glad to hear you found out what's wrong with it!!!!!!!!!!!!
Old Feb 20, 2003 | 10:48 PM
warrior007's Avatar
Dont feel bad, I did the same thing once but on a car.
Pulled it out of my garage after taking all weekend to do a head gasket. Got about 10 feet up the road and it shut off. Found out it sheared the placement pin off the cam so it was just spinning on the bolt. I couldnt get the hardened pin out so I spun the cam gear 180degrees and drilled a new hole for another pin. I felt like a tool but it still runs to this day. I think it has more power too since I "degreed" in the cam
Old Feb 20, 2003 | 11:07 PM
FireFly's Avatar
That sucks! I did the same thing on mine.But, it sounds that you got away pretty cheap. I wasn't so lucky, I had to have new cam, piston, head, haed cover, timing chain and sprocket.Learned a hard lesson on hopping up raptors.
Old Feb 20, 2003 | 11:11 PM
SANDMAN430's Avatar
hey i did the same thing had to get a new cam and timing chain.oh well i know the engine well.
Old Feb 20, 2003 | 11:21 PM
wshrdskin's Avatar
How does the lower cam chain gear look? With the chain crumpled up down there you'd think it would'nt fare to well.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
cornermike
Jun 3, 2015 07:27 AM
hoopduerr
Jun 2, 2015 09:01 AM
blaze_master
May 26, 2015 11:18 AM
