2 Finger Clutch Lever
Old Feb 26, 2003 | 01:01 AM
RepTaR660r's Avatar
Default 2 Finger Clutch Lever
Hey, I'm looking for a good aftermarket clutch lever and perch. I use to have a MBR perch. It was ok for a while. Terrible design, terrible finish, terrible quality. Its broke now, and I have been useing the stock clutch lever since. With the new engine and all I can't shift fast enough and hold on at the same time. I'm so use to just useing 2 fingers!!! Any ideas on a good quality shorty lever and perch would be great... Thanx
Old Feb 26, 2003 | 01:12 AM
donzilla's Avatar
call BRIAN at the quad factory . RTC racing . his levers are awsome . plus they have a full warrenty . you break them he will replace them . www.rtcracingproducts.com or 1-918-622-4998 Don
Old Feb 26, 2003 | 01:22 AM
RaptorRacer1's Avatar
You may check out the Yamaha Works YZ clutch lever. It is not much shorter than stock, but it has a smoother pull, is BLACK, and has a GOLD colored quick adjust ****. I know Alba sells them , and I bet any Yamaha dealer can get them.
Also, another option, if you have trouble wrecking and breaking you levers, is the one that is spring loaded. The lever can spring backward in the event of a crash, reducing the chances of a breakage. I can't remember the brand name, but it is something like AMD, ARM, ATC, ATP, RTC. Something like that. Good luck. Let us know what you end up with, as I am always looking for the latest trik parts to make me go faster!
RR1
Old Feb 27, 2003 | 05:12 PM
tanstaafl's Avatar
Its asv
http://www.asv-usa.com/
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
clscott84
Sep 21, 2015 10:16 AM
