banshee throttle sticking
Old Feb 28, 2003 | 04:09 PM
trigg's Avatar
Default banshee throttle sticking
i've been out today ridding, as normal the weather in the uk is wet, very wet
anyway the track i was riding at had loads of puddles muddy puddles at that, and i'm missing the rubber drain plug at the bottom of the airbox and run a kn filter, would this be enough to suck up some of this dirty water and make both throttle slides stick at full throttle
jeff
Old Feb 28, 2003 | 04:22 PM
AlkyBurninX's Avatar
Chances are you have got mud or water in the throttle cable. Are you still running the TORS?
Old Feb 28, 2003 | 04:54 PM
trigg's Avatar
no the TORS has been removed and im running a twist throttle
jeff
Old Feb 28, 2003 | 07:15 PM
You probably have a cable problem. Take the tops off and see if it is still sticking.
Old Mar 1, 2003 | 02:41 AM
cb1bo's Avatar
I have a 96 banshee and when the weather gets wet I can be sure of one thing, my throttle will stick. I've changed cables, lubed cables, thought I'd tried everything. Nothing so far has worked, if you figure it out let me know. I now have a trinity single carb kit coming because I don't know what else to do.---joe
Old Mar 1, 2003 | 11:29 AM
trigg's Avatar
if i rev it full throttle it returns to idle until i touch the throttle again,i was thinking it was the slides looks like i might be wrong
jeff
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Brandon400
Sep 7, 2015 12:20 PM
