Raptor 80 Lights
Old Mar 2, 2003 | 01:52 AM
Raqmenace's Avatar
Default Raptor 80 Lights
Does anyone here know where you can get some lights that can be fit into a Raptor 80. I talked to a guy that said he had done this for his daughters, but I can't remember the specifics. There is already a wire for the tail light, you just have to get the light and hook it up.
Thanks
Old Mar 2, 2003 | 12:29 PM
Raqmenace's Avatar
Anyone?????????????
Old Mar 6, 2003 | 12:05 AM
Raqmenace's Avatar
Does anyone have any suggestions?
Old Mar 6, 2003 | 12:12 AM
wshrdskin's Avatar
I'd be interested to know as well. We have an 01 Badger and would be interested in this. This wire you speak of for a tail light, where about is it located? TIA
PS, sorry to make you look only to find another inquiring mind.
Old Mar 6, 2003 | 12:35 AM
RaptorOwner's Avatar
These are cheap and real bright. I got a pair for my 300ex and now I got a pair for the Z400. Click Here
Old Mar 6, 2003 | 08:18 PM
Raqmenace's Avatar
Hey Wsh,
On the '03 raptor its right under the seat zip stripped to the frame. You can see it plainly without taking the seat off.
I believe it is only for the tail light though. No brake light.
Old Mar 6, 2003 | 08:46 PM
95wolv's Avatar
What I used for a tail light on an LT80 was a boat trailer red side marker light,got it from Walmart for a couple of bucks, it has 2 mounting tabs built in, looks very nice and is plenty bright for a little light. For a headlight, find a small, low wattage light, 35 watts or smaller, to limit battery drain, as the mini quads don't have a lot of juice to spare.
Old Mar 6, 2003 | 09:01 PM
Raqmenace's Avatar
Thanks, I'll look into that.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 6, 2003 | 09:02 PM
wshrdskin's Avatar
Thanks.
I wonder if they did the same for the Badger, I mean, it's the same freakin quad after all. [img]i/expressions/face-icon-small-smile.gif[/img]. I'll have to go out and check it out. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 22, 2003 | 09:23 AM
like2wheel's Avatar
It's been a couple of years, but I went thru this with my kid's badger. I dont remember the the stator output, but it wasn't enough to power most lights. I used a small L.E.D. marker light for a taillight (from local NAPA store) because they use very little current. I think 20 watts was all I had to work with for headlights without it discharging. I figured I'd better use something halogen to get the most output & ended up using a set of those micro fog lights & replacing the bulbs. I found 2 10w mr11 bulbs @ some x-mas light store, but decided that 1 20w bulb (found @ Home Depot) seemed to give more light. Hope this helps.
Aug 21, 2015 01:23 PM
HYS
Aug 18, 2015 12:28 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
