Some Guidance With My Blaster Please
Old 03-09-2003, 01:05 PM
Kyonicrr's Avatar
Default Some Guidance With My Blaster Please
Hi i have a 2003 blaster and i am needing some info on a coupple of things please tell me everything you know
1 I want either the Toomy kit or the FMF SST With SST Silencer. I do mostly trail and field riding and sometimes like on weekends we go to a tract and race but that like one time ever 2 months. Whick pipe whould be the best i dont race so that might help. And i dont want to have to be fixing crap
2 Should i get a rad Vale or just reeds or just get the pipe and silencer and a air filter and leave it at that?
3 i am also geting razor 2s rear tires
Old 03-09-2003, 01:53 PM
Peltrax's Avatar
Well the pipe depends on what you want ,the toomey is more of a mid to top pipe(which means it will give you more power the more you rev it out)and the fmf an all around pipe..I would get the toomey,i have it and ive never had any problems with it and ive never seen a faster blaster pipe.....get the reed valve if you have the money(v-force is the best) i put in reeds becuz mine were old and i hardly noticed anything.Yes the razrs are good tires,i have the originals,they hook up good and slide a lot better than stock.I would reccomend the 20 inch size
Old 03-09-2003, 10:58 PM
Blaster96's Avatar
I would so for the FMF. I do not own this pipe, but since the toomy is mid-top, that would not make your engine happy in the woods, i Run a Bills
Any air Filter will he l ur engine breath better, i run a UNI.
I would suggest the reed valve, they are much better than just reeeds, but just reeds are a lot better than the stock ones. Either way low end will be increased.
I run bandits for my rear tires. They are great in the mud and flat for the woods.
After ANY engine mod you will need to rejet. good luck. Do a search for rejetting, it has been covered many times on here.
Old 03-09-2003, 11:34 PM
YFZRacer's Avatar
my toomeys work great and i know fmf works well good luck ya razrs work good as well as holeshots good luck later
Ahtatu
09-28-2015 12:14 PM
nastyblaster100
09-13-2015 01:19 PM
1966F100
08-21-2015 07:10 PM
scott1988
08-18-2015 08:44 AM
315blaster
08-08-2015 08:13 PM
Quick Reply: Some Guidance With My Blaster Please
