please help, I have a HUGE problem
Old Mar 17, 2003 | 05:02 PM
kyraptor23's Avatar
Default please help, I have a HUGE problem
I replaced my dynojets with mikunis yesterday, which made an enormous difference. My mid range was hesitating so i dropped the clip on the needles to the 5th slot. As i was riding, it started missing terribly in the midrange. I rode it home and took out the needle in the left carb. The holder that holds the needle down had popped out while riding. Well I am missing the tiny washer that goes on top of the needle clip. I have looked EVERYWHERE and the only place it could have gone is through the intake boots that connects to the head of the motor. I have looked in the carb, the whole airbox, everywhere. What should i do?
Old Mar 17, 2003 | 05:14 PM
warrior007's Avatar
My buddies did the same exact thing, it ate the washer. It was never found but runs fine after we replaced it.
I wouldnt tear it down, you will probably not find it anyway. Its small and soft enough it should not be able to do major damage and probably floated on out the exhaust.
Old Mar 18, 2003 | 12:04 AM
kyraptor23's Avatar
come on give some advice please, i thought that was the purpose of these forums. Greatly appreciated
Old Mar 18, 2003 | 12:24 AM
ClutchOlds's Avatar
Ok some advice, get a new washer and not worry about the old one. It shouldn't hurt anything.
Old Mar 18, 2003 | 12:25 AM
kyraptor23's Avatar
thanks
Old Mar 18, 2003 | 04:04 PM
RacinJason's Avatar
HAHAHA I used to eat parts bigger than that when I was a little kid and it never hurt me. If you don't se it in the intake track I'm sure it bounced around and either became part of the top of the piston or worked its way out the exhaust valve and zoom right out the pipe.
Old Mar 18, 2003 | 04:21 PM
LOWBOWTIE's Avatar
Don't worry about it the washers are very soft metal. If it did eat it that is.......
Old Mar 19, 2003 | 12:50 PM
Chimmer's Avatar
Dump the Dynojet kit altogether & use Mikuni needles/jets.
Old Mar 19, 2003 | 01:43 PM
Dfitz's Avatar
Where can you get the Mikuni needle, jets and how would I go about making sure I get the correct sizes? My specs were set up to the yoshi specs they gave with exhaust, not sure of the size could look it up. Why are the Mikuni's better?
Nondem
Feb 22, 2020 12:20 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Gtsordo
Jul 22, 2015 01:27 PM
hondarider1234
Jul 21, 2015 11:53 PM
