wolverine is smoking!!!
Old Mar 27, 2003 | 08:16 PM
mudkid's Avatar
Default wolverine is smoking!!!
when i hold the throttle wide open or 3/4 in any gear even for 10ft then let off it smokes it seems to do this more when the engine get warm. can someone tell me what could be wrong???
2003 wolverine stock for now
Old Mar 27, 2003 | 09:26 PM
Juice's Avatar
Take it back and let the dealer figure it out, sounds serious.
Old Mar 28, 2003 | 12:56 AM
GYTR's Avatar
How did you break it in? Did you run it hard or did you take it easy for the first few hours?
Old Mar 28, 2003 | 01:25 AM
Hossblur's Avatar
bad gasket letting oil through?
Old Mar 28, 2003 | 06:36 PM
mudkid's Avatar
i drove it really easy for the first 4 or 5 hours then got where i would run in 5th gear about 1/4 throttle and i never opened it up to after two tanks of gas. i changed motor oil in it so could it be the oil i am running i am running castrol gtx sae20w 50. so should i swith over to yamalube or whatever it is and see if it stops it??
Old Mar 28, 2003 | 08:01 PM
Wolverine31's Avatar
Was it fine before you changed the oil?
Old Mar 29, 2003 | 12:54 AM
mudkid's Avatar
ya it didnt smoke at all then unless it was really cold outside
Old Mar 29, 2003 | 02:25 AM
GYTR's Avatar
I dont think it will really matter what kind of oil is in it. Did you check the oil level? Maybe you put to much oil in. I am not sure though
Old Mar 30, 2003 | 01:20 AM
Blaster96's Avatar
I run Castrol GTX 10w-40 in my warrior and it is fine, and also in our wolverine. I would use all of the above suggestion from above. Since it is a new quad i would take it to your dealer of purchase and tell them to check the head.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
