somethin wrong with my Raptor???
Old Apr 15, 2003 | 05:31 PM
  #31
warrior86's Avatar
Default somethin wrong with my Raptor???
ok thanks ill give that a try this weekend. quick ?, would being at a higher altitude make me run rich or lean...usually? and what improper jetting give me this kind of a nonexistant power? as usual, thanks
Old Apr 15, 2003 | 07:29 PM
  #32
warrior86's Avatar
o and i was told that high grade octane is actually worse and is only meant for high compression modded engines?
Old Apr 15, 2003 | 08:44 PM
  #33
warrior86's Avatar
alright, i guess everyone is sick of my questions. Ill just see if its the jetting and hope that its it.
Old Apr 15, 2003 | 09:17 PM
  #34
shutupholdon's Avatar
How can I find out what altitude Im at? I live in Lafayette, Indiana. Yo warrior, seems Im having a similar problem as you, if you figure something out let me know.
Old Apr 15, 2003 | 10:04 PM
  #35
Hayseed's Avatar
An elevation increase makes you run richer, therefore run a smaller jet size the higher you are. I always ran premium gas (not race gas, just 91, 92, 93) in my snowmobiles and never burned one down because the carbs needed cleaning. It was always the guys running the cheapest gas who would have green needles after they sat awhile and took them out and wicked them. Instant meltdown.
Old Apr 16, 2003 | 03:29 AM
  #36
warrior86's Avatar
yes, i will definately let u know u know.
So does running richer gives u less power?
Old Apr 16, 2003 | 07:52 PM
  #37
warrior86's Avatar
please excuse my ignorance but the electrode is the thing where the spark goes in between correct?
Can someone tell me if running rich causes less power? thanks
Old Apr 16, 2003 | 08:06 PM
  #38
sixsixT's Avatar
Running to rich or to lean will cause you to have less power. Stock they are a little lean to help with emissions.
YOUR RAPTOR IS FINE!!!!
Old Apr 16, 2003 | 08:14 PM
  #39
warrior86's Avatar
quote from "shutupholdon) In first that thing should wheelie over just by mashing the gas, Mine would stand straight up with me sitting on the gas cap even when it was stock no mods in first gear...in the grass. When you gas it in second you should have to do it with caution so the front dosent wheelie up, if your bike isnt performing like that...bring it in have them check it out.
He thinks it isnt? Im torn?
Old Apr 16, 2003 | 08:43 PM
  #40
That quote was from feedmespeed. I have to pull up on the bars to wheelie in 2nd, and cant even get it to wheelie in 3rd. I thought this was normal.
