Big bear running poorly?
Old Apr 16, 2003 | 08:26 PM
newtatttoobob's Avatar
Default Big bear running poorly?
My 98' big bear 350 4x4 runs poorly when the engine is cold. I mean it can be 80 degrees outside and if the motor hasn't been run and you start it and try to take off it will stumble and stall. Once it warms up it runs perfectly. When the weather is below freezing it has to run with the choke on for at least ten minutes then with no choke for ten minutes before I try to ride it. I don't think it should have to idle this long before i ride it? Any thoughts what could be causing this? Thanks Bob
buckshit
Sep 24, 2015 08:49 PM
Stillonit
Jun 18, 2015 11:23 AM
robj
Jun 15, 2015 08:45 PM
volsgo30
Jun 4, 2015 06:07 PM
hoopduerr
Jun 2, 2015 09:01 AM
