Quad Repair help (SUNL)
Old 02-24-2013, 08:34 PM
camatulli's Avatar
Unhappy Quad Repair help (SUNL)
Before you start, Yes, i know, SUNL is a parts nightmare...
I received a SUNL ATV from my in-laws (free) that was sitting in a garage for 3 years (fuel on)... I replaced the battery, a couple cables and the plug, and got it running... Now comes the problem... the carb is shot. the float and the pin are essentially destroyed. it runs for about a min then dumps gas out one of the tubes at the top of the carb, then drowns itself.
I've been on a quest to find a new carb without any luck...
What i'm hoping for is someone on here can either tell me a compatible carb, rebuild kit or the best place to find a carb for a 2005 SUNL SLA-150.
Thanks for any help you can provide...
Old 02-25-2013, 11:00 AM
alawoodchuck's Avatar
There's plenty around and I think they're the same. Here's a link. SUNL 150cc ATV Carburetors | SUNL Carburetors | SUNL Parts
Old 03-03-2013, 04:52 PM
armagh's Avatar
If you get another one, I would love to have the screws that hold the bowl on.
Old 03-03-2013, 10:04 PM
mudmike's Avatar
Just go to your local home center or part store. Tell them you need some m4 bolts about an inch long.
Old 03-03-2013, 10:54 PM
armagh's Avatar
OK mudmike, I will do that, even though a one inch screw will be way too long I can cut them off and if I have to I can tap the bowl of the carb.and make them fit.
Or maybe, put some duct tape round and round the bowl to hold it on, or J B Weld it on.
Old 03-03-2013, 11:15 PM
mudmike's Avatar
you shouldn't need to tap them 99% of chinese carbs usa a m4 screw. If 1 inch is too long yes it can be cut or just buy several leghths when you get them cause the screws shouldn't be but 10-15 cents.
Old 03-17-2013, 08:04 PM
camatulli's Avatar
Thanks for the link to MotoPartsMax, in my quest, they did come up.
ARMAGH,
As soon as i pull the carb out i'll let you know. i'm going to attempt a rebuild first (not likely), so the parts of the carb will be fare game.
Old 03-17-2013, 08:12 PM
camatulli's Avatar
Curious question... has anyone ever tried to swap out the Chinese carb with another brand? What else would have to change?
Old 03-17-2013, 08:16 PM
armagh's Avatar
camatulli, The rebuild will be easy. There is not much there to do wrong. You can do it easy.
Old 03-18-2013, 11:00 AM
I don't see any brand on my carbs maybe because I don't look but I can tell on the pictures on line if it's the same. Be careful to get the same kind of choke you already have. Leaver on the carb or attachment for a cable from the handle bar.
Chillibean
1) Engine problems..
09-05-2020 04:02 AM
Frisky2050
04-09-2020 11:19 AM
greg74
09-10-2019 03:03 PM
Sandman2.0
07-21-2015 09:03 AM
toonces
07-21-2015 02:40 AM
Quick Reply: Quad Repair help (SUNL)
