2005 650 v-twin
Old 02-07-2016, 09:07 AM
shaddysfx's Avatar
Default 2005 650 v-twin
carb question, is there two gas inlets or is one a overflow, I am guissing the one on top is the inlet and the one on the left is a overflow any remarks many thanks
Old 02-07-2016, 09:47 AM
Fasteratv's Avatar
There should be one fuel inlet per carb...each carb has it's own. The only "overflow" that I know of on the carbs is the nipple protruding from the carb bowls....one on each bowl and should have a very small hose connected to each. This is the Kawie 650 twin...right?
Old 02-07-2016, 10:21 AM
Should have a tee fitting for atmospheric vent tube,another tee that branches off on the fuel. See if this parts diagram helps.
Old 02-07-2016, 10:25 AM
shaddysfx's Avatar
this is a kawi engine , the one on the top of carbs is brass the other one is plastic ,looks like it might be for water between the chocks
Old 02-07-2016, 10:29 AM
shaddysfx's Avatar
the plastic one on the digram is no 7 looks like. So you are saying there should be a tee in the gas line to branch off to each fitting
Old 02-07-2016, 10:31 AM
Had Arctic Cat on the brain,sorry.. Principle is still the same on most twin carbs. Have to have an atmospheric vent,usually at the top or middle of the carbs separated by a tee into a single tube. Same for the fuel supply.
Old 02-07-2016, 11:03 AM
Fasteratv's Avatar
There is another tee...and yes its for coolant....coolant flows thru both of these carbs. Send a pic and we can provide better feedback....if you need it. I did the P700 carbs about a month ago, but I don't them very often and I am developing the "CRS" syndrom...
Old 02-28-2016, 08:49 AM
shaddysfx's Avatar
there seems to be one gas line in to the carbs. Now were does the tee on the left side of the carbs runn to , would this run down to the bottom of the waterpump or is this a overflow running back to the gas tank. My manuels does not give this info
mtnxtreme
02-08-2016 05:19 PM
amalota
02-05-2016 01:45 PM
JOE3824
02-01-2016 02:52 PM
jgar
01-25-2016 05:14 PM
frankmako
01-17-2016 08:51 PM
Quick Reply: 2005 650 v-twin
