4x4 disengage
Either the armature plate is magnetized in the front diff or the plastic roll cage is broken,or both. Upgrade aluminum roll cages are on ebay and if you have to tear into the front diff,this is the way to go. Item#10 is the roll cage.#31 is the armature plate.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Plenty of roll cages on ebay.Polaris Sportsman 450 500 700 800 Aluminum Front Differential Roll Cage Sprague | eBay
update , i took it apart this weekend ,the cage looks perfect, no cracks no burrs, moves very smooth the armature plate is fine it has 2 track marks ,even all around, i powered up the magnet with the cover off and it grabs the plate very well but when you power down it takes maybe 10 or more seconds for it to fully release.i watched the videos you sent..thanks for that..i put the cover on and powered up and it locked both sides as it should when i powered off it did not really release it. i turned the input shaft back and forth a few times and then it released.also the armature plate is not magnetized but the coil is slightly magnetized all the time.you can feel it when you lift the plate off. sorry for the long text.
i have an update on this thing ,pulled the front diff out, the roll cage seems perfect no scars very smooth operation.the armature plate is flat and has 2 even rings around it looks good and is not magnetized.so far everything looks good. now,, the coil reads 27 ohms and the magnet on power up grabs very well but releases very slow. the coil is slightly magnetized with no power to it. your input is very much appreciated
CrimsonTideJosh
07-22-2016 10:21 AM
AC-Greeny
05-08-2016 04:03 PM
