blue smoke
Old 01-16-2013, 07:21 PM
crispy1960's Avatar
Default blue smoke
My '83 honda 200E burns oil and bogs at full throttle, would this be rings, valves or a timing issue?
Thanks for opinions.
Old 01-16-2013, 07:30 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
yes- it could be rings, valves and any one of a dozen other issues.
you need to do more diagnostics. compression test & cylinder leak down test at the least to determine if it's rings, valves, burnt piston, scored cylinder wall or a gasket / seal issue.
there are literally dozens of things that would make an engine bog- it's impossible to tell what's causing your issues with the little info you provided. The burning of oil and bog down could be related (it's certainly not helping any) but could also be unrelated. Fuel issues, electrical issues or mechanical issues. sometimes it's just easier to pull the cylinder off and do a good inspection. It's cheap & easy enough to rebuild a top-end, and it couldn't hurt none.
Old 01-29-2013, 07:30 PM
crispy1960's Avatar
Thanks, I will get at it this spring.
EIF
04-20-2017 07:15 PM
CosmoM
09-21-2015 04:57 PM
xreynolds95
Technical and How-To Articles
09-21-2015 04:51 AM
bvolks
09-13-2015 12:57 PM
Quick Reply: blue smoke
