Tao Tao atv 110d Front right (when Sitting on it) Tire wont spin. Brake issue
Old 12-24-2013, 02:14 PM
alanwest09872's Avatar
Default Tao Tao atv 110d Front right (when Sitting on it) Tire wont spin. Brake issue
Hey guys if someone could help me get this situated I would appreciate it. The front right tire wont spin. I believe the break it holding that tire in. The front left tire is spinning fine. How do I fix this issue. I am below Novice When it comes to this stuff
Old 12-24-2013, 03:00 PM
Jaster94's Avatar
are you familiar with just a simple brake caliper system? like on your car? same thing. also check out the level of brake fluid in the reservoir.
Old 12-24-2013, 06:03 PM
ok will do that next. My brother changed the oil today with that have anything to do with this?
Old 12-26-2013, 12:15 PM
Jaster94's Avatar
no, not at all. 2 different systems.
Jaster94's Avatar
quads usually use DOT 4 brake fluid though.
Old 12-27-2013, 10:01 AM
when he put it togeather he put the nut on way to tight. It actually damaged the washer pushing it in. This is why the wheel wouldnt turn. Lol had nothing to do with the breaks.
also the front lines dont use break fluid on mine.
Old 12-27-2013, 10:30 AM
DFW Rusty's Avatar
Hey Jaster, a lot of these smaller Chinese atv's don't have hydraulic brakes. Just the old school cable brakes.
Old 12-27-2013, 10:33 AM
DFW Rusty's Avatar
Glad you were able to figure out the problem. I was going to tell you to loosen the nut on the brake line until it was completely slack, then re-tighten it. On cable brakes always tighten it until you feel a slight drag on the tire, then back it off about a 1/4 turn. Then use the threaded adjuster on the brake handle to do the fine tuning of the brakes.
Old 12-27-2013, 03:59 PM
Jaster94's Avatar
my bad! i haven't messed with them except a couple of them which were electrical shorts. i haven't ever inspected the brake system on them. i just presumed....won't be long with grandchildren coming along that i'll be getting the kiddie quads for them and keepin them going. so in the meantime, i may grab a couple of them and rebuild'em to learn the ins/outs of the little ones. thanks DFWRusty!
tycobb
ATC 3-Wheelers
10-23-2015 07:37 PM
txkevin
09-21-2015 02:02 PM
scaldwellk
06-19-2015 05:08 PM
Steven Bandemer
06-09-2015 08:50 PM
UPLou
06-07-2015 09:42 AM
Quick Reply: Tao Tao atv 110d Front right (when Sitting on it) Tire wont spin. Brake issue
