99 sportsman 500
Transmission is basically the same with the exception of the speedo function and gear position switches. Your 98 has the analog speedo with the cable running back to the transmission. The gear position switches are in the shift box. The 99 switched to the electronic speedo and switches on the transmission. You can possibly use the transmission and use your speedo adapter on the output shaft on the 99 that's blocked off. Same for the gear position switches that you could just leave on the transmission and use your old gear shift box. 98 transmission.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse 99 transmission with the gear position switches on top. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
chingchangchong
08-07-2022 11:36 AM
slowgsxr97
09-08-2015 07:33 PM
cdstang
08-31-2015 07:52 AM
