rubicon is down again... dreaded blinking shift indicator code 3 on ecm....
you guys know my story... got every thing running great last week. went riding last night..... got a total of about 20 miles on it since the second rebuild... no problems last night every ting was great. i came home and left on it on the trailer and this morning i went out and fired it up, backed off the trailer, and took it around the yard a few times before parking it to clean it. i spent about 30 mins washing every thing, had a good bit of sloop on every thing. well after i got done, i fired it up and now ive got a code 3 on the ecm flashing.... did some research and found this goes to the gear position switch... i checked all connections for water, blew dry with compressed air... even took the siwtch out and inspected it... no luck.
i tried to do the test described in the fsm but i cant seem to get the plug out of the ecm, and im scared im going to break it. i plan on getting a new gear position switch monday but its just odd to me that it happened right after i washed it...
any thoughts ? this has been over 4 hours or so since i washed it and i tried to make sure all plug connections were dried out so i dont beleive ive got water any where it shouldnt be
any thoughts ? thanks in advance guys
yeah i just did that. on the swich side, every thing is normal. i can see the switch select each gear.
i dont know if this matters... but on the harness side i can read to ground on all 4 pins....
is there a trick to getting that plug off the ecu ? id like to make sure theres no water or any thing in side it.
a few more details....
when i first start the bike, i see neutral just like normal. neutral light is on. i shift it into drive, and i see D appear, altho neutral light stays on. after a few seonds THEN then blinking starts. I can see it shift into R, N, D back and fourth if i do it quickly. However the green neutral light stays on constantly. What controls the neutral light ? i think that may be my problem. what ever is keeping that neutral light on, is contridicting with the ecm maybe ? i dunno, help me guys. thanks
here is how i tested the gear position switch.
un pluged from the harness, i made sure that in each gear, r,n,d,l that ONLY that corrosponding wire read to ground. i also made sure that no others read to ground.
The neurtal light is staying on constantly, but the dash screen sees me changing gears. its only after 2 seconds or so after being in that gear, that the blinking starts.
well i managed to make my problem worse. yay.
im pretty sure i broke the main ecu plug on the wire harness... thanks to it being glued in for some stupid reason... i guess the ecu is trashed also, because it wont even start now.
im out of patience, money, and time on this thing so im finished if it for a while.
you get what you pay for... buy a broken high mileage rubicon, spend a bunch more money on it and yo still only have a broken high mileage rubicon.
Sw00p
09-24-2015 02:50 PM
