Grinding Gears.
Grinding Gears.
After making sure it is not a rear axle bearing, the engine may need removing and the gears and bearings on the transmission need to be inspected. If one end of the main or countershaft goes out, the shaft will be allowed to let the gears not mess totally in some gears. An inner gear sleeve could have worn out or the inner gear mesh teeth can be damaged. One more thing... Bent shift fork.
Reguardless the engine will need be split
----- Gimpster -----
