LED bulb replacement for Sportsman 90?
These are 5 or 10 watt watt standard bulbs, just barely light up the area in front of the atv. Granted the later 4 stroke models have a larger 50 watt output than the 32 watt system on the older model 2 strokes,but people have had a hard time to find anything that could replace them. Had a lot of folks that came into the shop that just got a small led light bar that worked better than the headlights. 7" LED Light Bar | Polaris ATV Or possible to replace the existing lights.https://www.amazon.com/Ourbest-offro...+bars+for+atvs
Thanks for the info. Th polaris is $$$. Was thinking something like this https://www.amazon.com/MICTUNING-SR-...D8AQBE780YB4R2
Maybe have this on a switch so that the standard lights are on when the switch is off and when you turn the switch on, the led bar turns on and the standard turns off. Sort of a High/low beam setup. That way both are not on at the same time. Oh - and mine is a 4 stroke model...
I was thinking of running a + wire from the battery with an inline fuse holder to a toggle switch then to a led light. Ground the negative back to the battery. Only concern would be is to make sure the switch is off when the quad is not running. using this type of light.
Hellla 357203001 ValueFit 6" Mini LED Light Bar
