06 honda rubicon 500 spit sputter no power on takeoff when warm
Been working on my father in laws 06 rubicon 500 es. It has a problem where once it warms up a bit it will spit sputter bog down even stall when trying to take off in 1st gear. It is electronic shift but shifts fine. I cleaned all jets in carb twice,checked float blew everything out good. very clean carb. Drained all gas in tank put new gas in checked small filter going into carb. I have even tried adjusting the air fuel pilot jet. Nothing has worked. The slide, needle and diaphram are fine everyting checks out. Air filter is good no leaks anywhere. It will go good if you pull choke when it starts doing it. So its obviously not getting enough fuel but what next? If used to run great
How did you clean the jets? Usually just soaking the jets in cleaner doesnt fully clean them. Did you carefully run a small wire thru the pilot jet ( or replace with new)? A small wire from a wire brush works well, though I use jet reemers? Sounds like the pilot is still dirty, also, change the spark plug and ensure the plug boot is all the way down on the spark plug. I would guess a Moderator will move this to the Honda forum.
Change the plug. I had one in here a few weeks ago, thought it was the carb...carb was clean. Felt the spark plug boot, was loose ( owner must have done this ), pushed boot all the way down...same thing. Changed the plug...ran perfectly. Loose boot caused the plug to partially foul. I repair ATVs.....I should have known better....
I just wanted to let you know you were dead on about changing the sparkplug! It fixed the issue. Runs great now. Just used ngk bkr5es think it had a 5e in it. The plug that came out was black,black. Wish every fix was this easy its been stumping my father in law for months with the sputtering issue!!!Thanks again
trapstar56
11-03-2015 09:07 AM
Thatguy23
1) Engine problems..
11-03-2015 03:10 AM
