Oil Pump Adjustment On a Scrambler ;1995 400 4x4
Old 08-21-2003, 08:23 PM
savage21's Avatar
Default Oil Pump Adjustment On a Scrambler ;1995 400 4x4
Ok first off i had broke the Spring 1995 scrambler 400 on the oil pump lever where the cable goes to break so i took the arm off to get the spring out and i went and got a new new spring and arm for {43 bucks} but the oil adjustment screw that the arm goes on well i think i twisted it a couple time not know what i was doing, and i went to put the spring on and it all went on easy put everything on thionking i was done, then i cranked it idled fine smoked a lil then i push the gas down and it does go anywhere real fast and it smokes a butt load, and before i broek this spring it ran great. but my Question is how do i adjust the oil pump... if anyone knows where i can look or if you know anything about this please write back i hate to bring it to the polaris dealer and give him a 100 or 2. i'm only 18 and money isn't the best of things for me right now. so.
Old 08-21-2003, 08:26 PM
scrambler123's Avatar
I would suggest getting oil injection block off kit. cheaper than buying more parts for your pump and you won't have to worry about it messing up again. you can get one from hpd, rcr, hotseat.
Old 08-21-2003, 09:17 PM
savage21's Avatar
I'm not into mixing oil and gas, i just need someone who knows about polaris to help me out .
Old 08-21-2003, 10:05 PM
savage21's Avatar
any scrambler guy/girl wanna help me out?
Old 08-21-2003, 10:09 PM
NCScrambler's Avatar
Look very closely on the arm and the pump housing, there should be lines on both of them. One line should line up when the engine is at idle and the other should line up at full throttle. The lines are hard to see, but trust me, they are there.
Old 08-21-2003, 10:39 PM
savage21's Avatar
i seen the lines but what am i trying to line the lines up with? lol thank you for your help tho
Old 08-22-2003, 12:24 AM
savage21's Avatar
anyone want to help me my e-mail is Mike128190
@aol.com
my instant messager
is
mike128190
Old 08-22-2003, 09:17 PM
Check your PM.
scram5050
08-19-2015 02:19 AM
WesTech
11
08-11-2015 07:55 AM
mitchxc700
08-10-2015 09:26 PM
maxjung
07-13-2015 05:11 PM
Mikea1978
07-04-2015 12:37 PM
Quick Reply: Oil Pump Adjustment On a Scrambler ;1995 400 4x4
