Hub oil leaking behind strut
Hi everyone, have a magnum 500. Read a few threads here about strut housing seals. I just had my hubs apart and noticed there was no fluid left in hub. i replaced the bearings and tried to remove the seal from back of the hub and wouldn't budge. Was afraid i would do damage and just left it. Whats the trick. Will this work for the strut seal as well. I added new fluid into hub and it just started pissing out fluid from the back of the strut down the ball joint. First time for me changing anything on the front hub area. Aka rookie LOL
You have to be able to slightly flex the cv joint and pull the strut out a little to slip the drive shaft out. Use a common seal puller and the old seal will pop out.Make note of where the old seal set in depth wise and also the direction before you pull it! You can actually use a marker pen around the seal back in the strut to use as a gauge on how deep to knock it in. The key is don't go too far or it will distort the seal and leak! Best if you replace the hub seal too while you're at it even if it doesn't show signs of leaking! It's a bitch to have to go back in since you were right there anyway!! This seal can be knocked out after you pull the rotor,but the new one has to be pressed in or you can damage it. Best to have a cheap bearing/seal installer OR a large socket to keep the strut seal straight. Powerbuilt 948004 Bearing Race And Seal Installer Set
Hub seal has to be knocked out with a punch! Pay attention to the way it's installed so the new one can be pressed in correctly with the seal lip facing the strut!!
What is the ideal install depth for the strut seal and hub seal?
What is the ideal install depth for the strut seal and hub seal if not marked?
Splined yoke lateral play
How much lateral play is considered too much play between the front differential output shaft and the splined yoke on the axle? The yoke on the right side is tight but the yoke on the left side has some play. I ordered a new genuine Polaris OEM yoke from Partzilla. It arrived and the new yoke has the same amount of lateral play as the old one. Do I need to find another front differential?
exmotocrosser
09-13-2019 06:12 AM
