strange problem
strange problem
Just took the 4weeler for a ride [99scrambler500], when I backed it out of the garage the left front wheel was dragging real bad, drives fine in forward, I just got the 4wd working [I think] and just replaced both front boots, it looks okay, I must have gotten something wrong on assembly. Any ideas???
Cheap as they are always best to replace the armature plates whenever you tear the hubs down. They have constant wear pressure on them even if not in awd mode. Over time they can wear down from riding against the coil sleeve and can magnetize or warp and cause a hub to lock up even if not in 4 wheel drive.Usually you can unlock them by going forward or reverse to unlock and they'll be ok,but mainly a nuisance especially when the hub fluid is cold. They can lock up in forward or reverse.Hopefully backing off the hub nut,then torque the nut to 12 foot pounds may solve the problem. If it still locks up change both plates out as usually the other side will do the same thing later on.
