will 26x12 tires fit new SP570?
I have a new wheel kit never used for Yamaha Grizzly. The bolt pattern is different so can't use on my new 2016 SP570. I can get a new set of nice rims for under $300. Specing them out I was asked if the 12" would fit the new SP since they don't the XPs per his understanding.
Does anyone know?
Thanks,
R'
Does anyone know?
Thanks,
R'
Doesn't the 570 come with 12" rims? If so, you won't have problems with 14" rims if the bolt pattern is the same. You run into problems with the brakes if you try to go from 14 to 12 inch rims. Judging from my son's Scrambler I think you'll have room for the slightly wider tires too. They moved a lot of the front suspension inside the rim. Ask your dealer to be sure.
Polaris' website shows the camo 570 in two versions. EPS and EPS SP. The regular EPS model comes with 12" rims. The SP comes with 14" rims. So, I think your's has 12". Just check the size on the side of the tire. If you want to go with 14" rims you should be okay as long as the offset is the same as stock.
moparz
04-30-2016 01:36 PM
