Fresh lt80 engine, no power
Old 09-16-2014, 07:09 PM
ninja11zx's Avatar
Default Fresh lt80 engine, no power
Picked up a 89 lt80 not running for the grandson. completly went through the motor. crank was ok,installed new bearings and seals. bought the cheap chinese top end off e bay. kit was pretty nice for the money. carb was completley gummed up so i cleaned it and installed a carb kit with new air filter. engine fires right up with the choke, it will run with the choke off and will rev fine with the rear wheels off the ground. put it on the ground and it won't go anywhere. it has no power. after reading a bunch of post i am thinking the clutch is locking up to soon. i have to turn idle way down or it wants to engage. is there a way to check timing on these?i put ignition plate back where it was. just looking for ideas here. thanks
Old 09-17-2014, 06:23 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Timing: On the stator, there is a line at the 9 o'clock position, you align that line with the line on the case.
I suspect you didn't get the front clutch back on w/o a roller or 2 flopping.
Surely you went thru the front clutch and cleaned it and the rollers up.
Rear clutch bearings good?
Old 09-17-2014, 11:29 AM
ninja11zx's Avatar
Thanks for the reply. Im thinking it's in the clutch.clutch was in nice shape, I just stuck it back together without paying attention a out the weights. Bearings in rear were ok. I'm guessing weights.
Old 09-17-2014, 12:52 PM
LT80's Avatar
LT80 Expert
Yep. You have to be very meticulous on the front clutch installation. If the roller plate comes off the rollers, you have to take it back off and make sure the rollers are in place...again...LOL
I apply side pressure on the crankshaft when I'm sliding it down on.
Old 09-17-2014, 06:57 PM
ninja11zx's Avatar
2 rollers were flipped. i am reading to leave 3 out. is this a good idea?
Old 09-18-2014, 07:49 AM
LT80's Avatar
LT80 Expert
NO, you can leave 2 out but top end speed may suffer a lil.
skinnyr6
08-25-2023 02:18 AM
bzdok1234
30
02-23-2016 01:55 PM
KimSJoh
14
07-18-2015 07:20 PM
RedRancher
07-10-2015 06:36 PM
tweeder
07-05-2015 01:57 PM
Quick Reply: Fresh lt80 engine, no power
