1986 lt 230 quadsport rear end adjustment
Old 12-28-2010, 07:34 PM
miller6951's Avatar
Default 1986 lt 230 quadsport rear end adjustment
Hi i have a 1986 lt 230 quadsport and When i adjust the chain I tighten the clamps down as far as they go. But the chain still loosens after a ride or two. This quad has new rear bearing new swing arm bearings new rear sprocket so it cant be any of those. Any suggestions
Old 01-02-2011, 01:39 PM
ktmbk's Avatar
is it that the adjuster loosens up and slips? or are the chain and sprokets worn out?
Old 01-02-2011, 04:24 PM
snow racer's Avatar
Get a good o ring or x ring chain. Is it a stock chain?
Old 07-05-2011, 02:41 PM
McFarling's Avatar
Default What brand chain did you get?
Did you get a low quality chain?
IF so it might be stretching every time you ride it.
Or if you are tightening the chain too much when you land off a jump or bump the chain gets stretched.
Remember to look at the chain adjustment with nobody on the quad, then get someone on it so compress the suspension to the full bottom and make sure it's not too tight at that point. If it it when you land the chain gets stretched at this point and can actually break.
STLyamwar
07-25-2020 04:44 AM
Backwoods_badass
08-02-2015 10:40 PM
NatePerz
07-27-2015 03:27 AM
JoAnnS
07-23-2015 02:18 PM
rcappie4
07-10-2015 04:54 PM
Quick Reply: 1986 lt 230 quadsport rear end adjustment
