what fluid do you put into crank case for blaster?
Old 08-24-2006, 10:18 AM
glock22's Avatar
Default what fluid do you put into crank case for blaster?
I want to replace the crankcase fuid on my wife's '95 blaster and need to know what to put back in it. Does it take simple geer lube, motor oil, or something special? Thanks.
Old 08-24-2006, 12:03 PM
oldturtle's Avatar
You are talking about your blasters tranny. Guys use everything from expensive 2 stroke specific tranny fluid to regular automatic tranny fluid to regular car/truck motor oil. The best is probably Yamaha 2 stroke tranny fluid. I use Chevron Delo 15-40 in diesel and gasoline trucks, all 4 stroke quad and motorcycle motors, and all 2 stroke trannys. So how much do you want to spend? The correct Yamaha oil is probably best for your clutch and tranny but the others do alright for plunking around.
Old 08-24-2006, 12:16 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum glock22! [img]i/expressions/face-icon-small-smile.gif[/img]
I use Bel-Ray Gear Saver in the tranny of all my 2 strokes. I use the 80wt version.
Old 08-24-2006, 03:30 PM
Storj's Avatar
Use only 10w-30 none synthetic motor because that is also the lube for the clutch and if you use something other than that you could burn up your clutch.
Old 08-24-2006, 04:56 PM
JLsparky7's Avatar
I would look into amsoil.
Old 08-24-2006, 07:52 PM
recon99's Avatar
I always prefered a mixture of sand and muddy water for blasters... j/k.
I'd stay away from using regular automotive gear oil or motor oil, that's what the auto parts store told my cousin to use on his 250r, and after that his almost new clutch mysteriously began slipping. You can buy oils specifically for the transmision of 2 strokes, or I think you would also be fine using motor oil for 4 stroke atvs and motorcycles because it's wet clutch safe.
Old 08-25-2006, 11:39 AM
Storj's Avatar
Look it up in the manual it says use only 10w-30 none synthetic motor oil.
Old 08-25-2006, 02:11 PM
JLsparky7's Avatar
there are also some bottles out there that say "dont turn upside down" on the bottom. What the manufacturer says isnt always right...
Old 08-25-2006, 02:19 PM
DrGsTer's Avatar
I use PJ1 80 or 90 weight. When I bought my blaster the dealer told me to use any motorcycle gear oil that is at least 70 weight. I tried the Bel Ray Gear Saver but I got more throttle response with the PJ1. I would reccomend Pj1 90 weight gear oil.
Old 08-25-2006, 02:33 PM
whaleedited's Avatar
Ive always used yamalube 10w 30 in my kids 2001 Blaster. Its had no tranny or clutch problems and it gets ridden hard. I think its worth the money to buy the right oil (not car oil,it can hurt the clutch) besides it doesnt even hold a full quart. so how much does it really cost?
Quick Reply: what fluid do you put into crank case for blaster?
