Yamaha warrior won't start
Old 01-18-2008, 05:38 PM
YaMaHa-WaRrIoR's Avatar
Default Yamaha warrior won't start
I have 2 uesd starters and all they both will do is turn over <u>buttt</u> the engine won't catch or something i checked the wires and everything [img]i/expressions/face-icon-small-confused.gif[/img]
Old 01-18-2008, 09:44 PM
mikester4586's Avatar
Having the same problem I was told to clean the carburetor out. I'm doing that tonight Friday at about 7:42. I'll Let you know how it goes. MIKE
Old 01-18-2008, 09:58 PM
87 warrior's Avatar
does the engine turn over at all or does the starter just turn. if your starter is just turning and not turning the engine over then you either have a defective starter or a stripped/broken starter gear or broken crank shaft. i doubt it's the crank shaft it takes alot to break them.
Old 01-19-2008, 12:24 AM
it's 10:18 I just finished cleaning the carburetor as well as ALOT of other stuff and will see in the morning if it will start. I don't think that the carb was the problem but I was told that it was so.... Mine turns over and everything just won't "pop", when I used starting fluid last week it started, but lately it won't start with anything. If it doesn't start tomorrow I don't know what I'm going to do. what could it be.
Old 01-19-2008, 11:44 AM
ah.. i called some guy in johnstown pa, and he said that there is a key somewhere by the stator he said if i tseted both starters and it does it with both he said that the key probably shatored they are like 2 to 4$$$ idk im gonna look in tow it this week thanx
Old 01-23-2008, 01:29 AM
warriorwild's Avatar
I put a aftermarket degree key from vitos in my 2000 warrior for a supposed perfrmance upgrade rode my bike for ten minutes and it shattered, I had your starting problem and had to put my stock degree key back in. This ten dollar part to advance my timing just caused me a lot of headache, I wouldn't recommend this upgrade. That may be your problem but I would check your spark b/f tearing into your engine.
njrider64
07-04-2017 01:40 AM
mikey426
06-17-2015 03:53 PM
dano00
10-07-2000 08:13 PM
PuhiStrain
09-09-2000 01:36 PM
dunc_n
08-26-1999 09:32 PM
Quick Reply: Yamaha warrior won't start
