86 moto4 250 weak starter???
hi all.
I just bought this atv for my wife as a fixer upper. It starts ok if I use a 100 amp booster at the starter but it wont turn fast enough to start the atv if i use a car battery and cables . I've cleaned and lubed the bearings brushes ect and the starter turns fine off the motor but same result afterwards.
how can i check engine to see if it turns freely ? This motor has no recoil or kick starter. I really dont want open the motor...
thanks for your sugjestions
pic of atv
i did some more trouble shooting and used the trucks battery to start the atv so i must have a weak battery.<br />
<br />
but it still was slow turning <br />
im gonna try the starter on my buddies atv.<br />
<br />
<a href="http://picwizz.com/i/32305-6873.jpg" target="_blank"><img src="http://picwizz.com/i/t/32305-6873.jpg" border="0" alt="" /></a>
dose anyone have a wireing diagram for it??
thanks
<br />
<br />
thanks
Get a manual for it, best money ever spent.
Try tradebit.com or ebay
My moto 4 80 acted the same, new battery, plugs, checked valve lash, rebuilt piston and cylinder, tuned carb etc. Got it running good but always hard to start cold.
Finally checked ohm reading on coil against manual and both the coil and the stator coils were off what the manual said in the ohm readings.
Replaced the coils for $55 and starts like new.
Buy yourself a $6 spark gap tester. Your spark should jump around a 1/2" gap
These go in the plug wire cap and conect to the spark plug so you can watch the spark while running the engine. Mine would only jump a 1/8" gap and the coils where the problem. On a 20 plus year old bike the ohm readings should be checked to verify the coils are in spec.
Ken
Ken
