beartracker reverse chatter?????
Old 12-07-2013, 09:50 PM
waybad's Avatar
Default beartracker reverse chatter?????
hello,
riding my 99 beartracker in the snow and when I was stuck, put in reverse the thing would start bouncing/chattering like it was missing teeth on a gear??? doesn't do it forward just in reverse?? if the tires are not spinning reverse is fine??
thanks for your time..
Tinker
Old 12-08-2013, 11:41 AM
TLC's Avatar
TLC
TLC is offline
I was going to say the rear diff pinion gears maybe getting worn but if that was the case its should do it in forward or backwards.
Here is a post about it http://forums.atvconnection.com/yama...driveline.html
Does it sound like this?
here is how it works
Old 12-14-2013, 04:05 PM
waybad's Avatar
mine starts hopping an acting like a tooth is missing,, just in reverse when it spinning,, stuck trying to back out of a hole!.. thanks for looking!!
Tinker
lonerider856
10-13-2023 03:45 PM
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
r1pilot83
09-27-2015 07:38 PM
poutlaw525
09-09-2015 03:19 AM
Quick Reply: beartracker reverse chatter?????
