2005 Yamaha Bruin 250 no strt frm strter
Old 03-25-2014, 08:17 AM
bruce3040's Avatar
Default 2005 Yamaha Bruin 250 no strt frm strter
I just replaced starter with new starter, put battery on charger starter cranks but will not start motor , starts with pull cord chkd fuses ,ok
Old 03-25-2014, 08:42 AM
Does the engine turn over with the starter or just the starter only turns? If so could be a starter clutch problem.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old 03-25-2014, 09:12 AM
bruce3040's Avatar
Default 2005 yamaha bruin 250 starting issue
yes the starter turns but motor does not , starts fine with pull start
Old 03-25-2014, 02:18 PM
First check you have the right starter. I once fitted the wrong brush kit to a starter and it ran backwards. The gear or spline on the shaft could also be wrong so check it against the old one.
Old 03-25-2014, 06:45 PM
bruce3040's Avatar
Default starter prob
I did and it is exactly the same motor
Old 03-26-2014, 06:50 AM
Then I'd check into the starter clutch area on the link I posted. Could be as simple as an idler gear problem if not the sprague clutch itself.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old 03-26-2014, 06:54 AM
bruce3040's Avatar
Default strter issues
ok is it hard to get at thk you
Old 03-26-2014, 07:15 AM
A cheap manual is worth it's weight in gold!http://www.ebay.com/itm/2004-2005-2006-2007-Yamaha-Bear-Tracker-Bruin-Big-Bear-250-Service-Repair-Manual-/300966433528?pt=Motors_Manuals_Literature&hash=item4612ff52f8&vxp=mtr
Old 04-06-2014, 01:31 AM
kawipolaris's Avatar
im having a very similar problem as you are and i have the same atv i just posted a new thread but can i ask if you fixed the problem yet and how you got the flywheel off to get to the starter clutch thanks and here is a link for the starter clutch for only $100 if you havent gotten it yet http://www.partzilla.com/parts/searc...TCH/parts.html
Old 04-16-2014, 06:33 PM
i found out my problem and it was that 2 of the 3 bolts that hold the starter clutch on the rotor i guess had sheared off somehow and i was able to get the ends of the bolts off with a magnet by turning it and then pliers. Check if this is your problem too because it may save you a bunch of money and ive heard that the 01-03 raptor 660s have the same problem. good luck
Ean
12-19-2022 08:48 AM
AlotL1keVegas
08-18-2015 09:38 PM
blessedn09
08-09-2015 03:07 AM
papahouse
07-28-2015 12:42 PM
tporath
07-11-2015 12:31 PM
Quick Reply: 2005 Yamaha Bruin 250 no strt frm strter
