yamaha bruin 250 wont start
The most common fault with the starter set up is the starter motor. Have you checked that this isn't the problem? If you have fitted a new solenoid and it clicks, the starter probably needs new brushes.
Brake or gearshift lock-outs, or the button itself are as likely to be at fault as a relay.
