1995 Yamaha Wolverine 350
1995 Wolverine 350 4x4 acts like its stuck on a rev limiter but doesnt have one... very low power thru all gears. this year didnt have the Ebrake plug so that wont fix this one! Runs and idles great but low power ! New carb bout 6 months ago and have cleaned bt didnt help... new plug and all... any guesses?
All you can do for a start is to check valve clearances, fit a new plug, and check if the old one is sooty or "death white." If that doesn't cure it, check compression, it should be over 90psi, clean the carb out again. If it still runs badly, you may have an electrical problem, coil, CDI, regulator, trigger coil or stator. The regulator can be checked by testing the volts across the battery with the engine running, over 15v and the regulator needs changing. Under 13v max, and either the regulator or stator is faulty.
Thanks for the info... i'll start somewhere... It just runs so good but rpm is limited to i'm guessing around 1500-2000rpms when i try to rev it up... no poping or backfiring! one thing i am wondering is the muffler has been gutted by previous owner.. will the lack of back pressure hurt it?
Dennis0862
1) Engine problems..
04-26-2016 08:20 AM
ragewraps
03-17-2016 01:27 PM
