Yfz 450 cranking problem
Yfz is cranking super slow almost like it doesnt have power to rurn the motor over it will crank once extremely slow then twice amd sometimes a couple times more then it will just click have tried everything I put a new battery new relay new starter new stator checked the timing and the crank and the valves and I have no idea wtf is going on! I brought it to the dealer and they replaced all of the and I'm about 600 dollor into it already and my headlights don't work once I finally get it going it seems to run great. Please help!!!
Sounds like a flat battery, did you charge it up? Some new batteries are flat when they come and have to be charged for an hour or so. If it isn't just that I would take it back to the dealer and tell them they haven't fixed it. Seems like they are not very good though, as they have been "throwing parts at it" instead of testing things out.
Take apart the starter/kill switch assembly. It has a drain hole or 2 in the bottom, but gets gunked up over time. I have had similar issues and on occasion the contacts have been dirty enough to cause poor starting. The other thing I do is hack that battery box up a bit and fit a larger battery in. You may need to fab up a bar to hold the batt down as well. Or go with one of those new lithium iron or whatever batts. The stocker is the minimum size for weight restriction, but struggles when you add anything that makes it harder to start.
04 Preddy
06-18-2016 08:32 AM
