Jetmoto Enduro 200cc motorcycle.
#52
I purchased a similar 200 motorcycle from Jet Moto and was wondering if anyone new if it is the same motor as the Yamoto. Thanks.
#56
I wanted to know if anyone knows how to adjust the valves. Also is there an adjustment for the cam chain? and if so how do you adjust that? The book i got with my bike is dissapointing and I don't want to trust the measurments in it so if you know what the gap should be for the valves i would appreciate your help. Thanks
#58
Alot of noise is coming from that area. Its probably just the valves but i don't see any adjustment for the chain and was just wondering if it could be adjusted.
#60
i took the cover off and found that there isnot a cam chain. the bike has push rods. i loosened the exhaust valve and that made it alot quieter thanks for your help anyway.
