HOW TO carb adjustment on any Chinese atv. Kazuma, Yamoto, Redcat, Baja, Sunl, etc...
Old Aug 12, 2015 | 08:57 AM
  #321
MPDano's Avatar
To me sounds like the float plunger isn't sealing. I always adjust my float upside down and make the float parallel to the carb bowl mount edge. Check the float plunger rubber and see if it's pliable.
Old Aug 12, 2015 | 09:51 AM
  #322
DanP24's Avatar
Plunger looks OK. I did a test by filling the fuel line with some cleaner and then moving the float up ever so gently. Flow stopped.
The float is definitely not in line with the bowl mount edge.. If that's the correct setting, then, it's definitely too high. That wouldn't be a 10 degree setting though... more like a 0 degree setting.
Old Aug 12, 2015 | 10:54 AM
  #323
MPDano's Avatar
Adjust it and test it by using a short piece of fuel line and blow into hose while turning the carb updside down and if it seals, then your good. These setting without measuring degrees always worked for me.
Old Aug 12, 2015 | 11:01 AM
  #324
DanP24's Avatar
Do you know what the jet sizes should be?
Old Aug 12, 2015 | 11:11 AM
  #325
MPDano's Avatar
Nope. I don't own a 110cc quad. I also don't think this is what is flooding your carb.
Old Aug 12, 2015 | 11:13 AM
  #326
DanP24's Avatar
Correct, the jet sizes won't be the issue, but was just asking in case you knew.
Old Aug 12, 2015 | 11:16 AM
  #327
MPDano's Avatar
Chinese carbs really are junk. Sometimes it's easier to buy the $14 shipped replacement than trying to troubleshoot these.
Old Aug 15, 2015 | 08:05 AM
  #328
DanP24's Avatar
Quick question.... air/mixture screw adjustment. which way to turn to lean it out?
Old Aug 15, 2015 | 08:21 AM
  #329
LT80's Avatar
LT80 Expert
Ethanol messing the float up.
The high fructose gas is sticky..LOL
Old Aug 15, 2015 | 08:39 AM
  #330
DanP24's Avatar
Not sure what you're saying. I just asked which way is what for reference. I think I solved my issue with the carb. I just want to know for fine tuning.
