HOW TO carb adjustment on any Chinese atv. Kazuma, Yamoto, Redcat, Baja, Sunl, etc...
Old Aug 15, 2015 | 11:42 AM
  #331
MPDano's Avatar
Originally Posted by DanP24
Quick question.... air/mixture screw adjustment. which way to turn to lean it out?
Close it and open 1-1/2 turns. That is a good starting point. Clockwise is leaning, basically closing.
Old Aug 15, 2015 | 11:47 AM
  #332
DanP24's Avatar
Closing = Lean out
Open = Enrich
So by that, the mixture screw for these PZ19 carbs controls fuel? If it controls air into the carb, then the opposite would be true.
Old Aug 15, 2015 | 12:29 PM
  #333
LT80's Avatar
LT80 Expert
Ethanol has been the cause for the float needle sticking and flooding the motor many multitudes of times the last cpl years and getting worse.
Alot of small motor manufactures void warrantys if ethanol gas is used.
I was chimming in on the flooding aspect.
Old Dec 17, 2015 | 04:42 PM
  #334
ronnichols's Avatar
My son just got a Baja wilderness 250, 2005 model. It was running very rough when trying to accelerate but seemed fine while idling. We followed your instructions and this helped quite a bit but it still starts sputtering at anything over about half throttle. Any other suggestions would be greatly appreciated. Thank You!
Old Dec 17, 2015 | 06:16 PM
  #335
thejunkman's Avatar
Sounds like you need a little bit of tuning. Generally these China ATV's are jetted lean from the factory. Try 1 step richer on the main jet and possibly the pilot jet. If you are unfamiliar with Jetting I advise you to read my page about the subject to educate yourself. It will direct you in the right direction.
Carburetor Jetting info and how to
Old May 9, 2016 | 04:36 PM
  #336
ladrevic's Avatar
Default Thank you
Following
Old Sep 14, 2016 | 02:31 PM
  #337
Prince Aboudie Hijazi's Avatar
You can find very similar information WITH PHOTOS on how to properly turn on your ATV for the first time and maintain it here:
https://www.belmontebikes.com/pages/...roubleshooting
The pictures/images really help.
Old Nov 17, 2016 | 09:40 AM
  #338
blammer's Avatar
are there any pics of the 250 cc for carb adjustment?
Old Dec 22, 2016 | 10:58 AM
  #339
Sarfraz Shafi's Avatar
Post how to fix slow rpm and acceleration carburetor
how to fix slow rpm and acceleration carburetor idle and start fine, once start it revs high rpm but after driving for 1 min it bogs down and has no acceleration or high rpm from dead stop? Thanks
Old Jan 12, 2017 | 12:44 PM
  #340
smithder's Avatar
Default Coolster Cuts out at WOT
I bought a 2016 Coolster 125cc for my son for Christmas. It starts and runs perfect but when you give it throttle past about 3/4 or goose the throttle from idle it cuts out. Any suggestions to fix this?
It is fine except when you need to give it the juice to climb a hill or climb something.
