jianshe help!!
#61
trouble shooting for js 400 jeanshee quad...
Yesterday i was riding bike everything worked fine except when i left my battery was down...so got a boost from friend...ok after riding for an hour or so the bike back fired and stopped....had a funny smell so i took the seat off checkek my battery and it was ready to melt...so hot that i had to pour water on it so it woulnt catch on fire....next thing had my gps plugged in and the gps kind of blew up....it cease working......so today i put brand new battery and still the bike wont start....so could someone help me regarding this. could it be the coil? Remi
#62
on
You're going to have to fix that or you will quickly wreck your new battery too. I would unplug your regulator for the time being and keep your battery charged up with a motorcycle battery charger when the quad is not being worked on. Once the quad is running then the charging system can be looked at next.
Re: Not Starting:
Does the starter motor turn? If it does, do you have spark? Do you know how to check for spark?
Does your manual have a wiring diagram in it?
