Tao Tao ata125D Throttle
Old Mar 18, 2010 | 07:12 AM
konefour's Avatar
Default Tao Tao ata125D Throttle
Are there any adjustments that can be made to the thumb throttle on the handlebar? What I mean is the thumb throttle can be moved about a half inch to a full inch before anything happens. It just feels loose and is hard to start off slow. Starts are really herky jerky because of this.
Thanks.
Old Mar 18, 2010 | 09:33 AM
OneTenCC's Avatar
There should be an hex shaped steel adjusting collar on the throttle cable to take up any slack like you describe. There's also the the black Phillips head screw near the thumb throttle used to limit the amount of throttle lever travel for young, inexperienced riders.
Joel
Old Mar 18, 2010 | 09:57 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Usually there is a adjustment in the cable.. just below the throttle.. Or maybe a adjustment at the carb?
Old Mar 18, 2010 | 12:40 PM
konefour's Avatar
I am familiar with the speed limiter, which I've used, and I will check the slack in the cable and see if there is any give there and check the collar.
Thanks!
Pehter
Oct 3, 2024 11:00 PM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
